Veakoodide lugemine kirjaklambriga ja pedaalide trikk
Q-tok
Postitus Postitas Q-tok »
Rather than pay a garage to read your engine fault codes, most engine ECUs can be read for free!
Petrol engines
2.0/2.5/3.0 Paperclip test
2.6/3.2 Pedal trick
2.2 Code reader required
Diesel engines
2.5 TD Paperclip test (some only, else code reader)
2.2 DTi Code reader required
Those needing a code reader or more advanced diagnostics performed, see http://theboy.omegaowners.com" onclick="window.open(this.href);return false;
Kirjaklambri trikk
NB!: 2.0l ei tööta see kui mootor käib.
Avakaitsmete boks . Vääna kirjaklabmer U -kujuliseks ja sisesta nagu pildil näidatud.
Turn on ignition, and count the flashes of the EML. Easiest way to describe is to watch this video...
http://images.omegaowners.com/images/gu ... rclip.html" onclick="window.open(this.href);return false;
Note: On a v6, if the engine isn't running, it is normal to get a 31. On a v6, you can do test again with engine running.
Note: Systems using 2 digit codes (2.5/3.0 and earlier 2.0), the system flashes a 1-2 (12) 3 times to indicate start of sequence. Systems using 4 digit codes (later 2.0l), there is no start of sequence - it starts flashing out fault codes (if any) immediately.
Pedaali trikk
Foot on brake, gas pedal to the floor.
Turn on ignition to position II (do not fire the engine in position III)
When dash lights go out the yellow light car symbol with a spanner through it should flash.
4 sets of flashes/numbers pause and so on.
10 flashes is zero.
Constant flashing no codes.
Video is here (thanks to chrisgixer ):
http://images.omegaowners.com/images/gu ... trick.html" onclick="window.open(this.href);return false;
and shows
10 3 10 10 =0300 random miss fire
10 3 10 2 =0302 miss fire on cyl 2
10 3 10 3 =0303 miss fire on cyl 3
you get the idea...
Q-tok
Re: Veakoodide lugemine kirjaklambriga ja pedaalide trikk
Kirjaklambri diagnosti veakoodid:
Enamus Omegate (nii A kui B) erinevate Motronic ajudega kehtivad need veakoodid
http://enos.itcollege.ee/~pnigola/Motronic.pdf" onclick="window.open(this.href);return false;
Ecotec 2.0 puhul (Simtec aju) kuni 96 aasta kehtivad need veakoodid
http://enos.itcollege.ee/~pnigola/Simtec-96.pdf" onclick="window.open(this.href);return false;
2.5 bmw diisel (96kw) veakoodid on siin
http://enos.itcollege.ee/~pnigola/2.5tdi.pdf" onclick="window.open(this.href);return false;
Pedaalide diagnosti veakoodid:
Uuemad mootorid e siis 2.2 , 2.6, 3.2 ning ka uus 2.0 ecotec ja uued diislid kasutavad universaalseid EOBD koode
http://enos.itcollege.ee/~pnigola/EOBD.pdf" onclick="window.open(this.href);return false;
Omega b, ´94a. ,juhtaju simtec 56.
Rooli all diagnostika pistikus sillata 5.ja 6.pin ära.Veakood 12-alustab ja lõpetab diagnostikat.
Postitus Postitas MegaHabe »
Kas see pöörlemissagedusesignaal puudu on vända andur?
Tegu siis 2,4 motoriga!
arska
Postitus Postitas arska »
kui mootor ei tööta siis tulepki selline vea kood.
seljuhul väg põnev kuna algas ta mul 21 ja lõppes 12 mis peaks olema nii alguse kui lõpu kood :shock:
ei saa enam muhvigi aru.
o:mega
Postitus Postitas o:mega »
Aga 2,4 mootor ja Omega B veakoodid?????
broadcast
Postitus Postitas broadcast »
Q-tok kirjutas: Petrol engines
2.6/3.2 Pedal trick
Ei vasta tõele. Minu 2,2 bensukal toimib "pedaalitrikk" täitsa edukalt... :roll:
redko
Postitus Postitas redko »
Tere küsimus kuidas lugeda veakoodi auto 1998aasta 100kw ec.
Ove
Postitus Postitas Ove »
Tere, kõik on ju kirjas :shock:
ovetegemised.wordpress.com
redko
Jah aga mul ei hakka tuli vilkuma 5ja 6 klemm sillatud????
igiliikur
Postitus Postitas igiliikur »
Ma ei saa ka nüüd hästi aru, esimesel pildil on 4 ja 6 sillatud?
erks932
Postitus Postitas erks932 »
redko kirjutas:Jah aga mul ei hakka tuli vilkuma 5ja 6 klemm sillatud????
mul sama auto ja kirjaklambriga väga edukas lugeda:)
5 ja 6 klemm omavahel kokku ( minul)
seitsmes pesa on tühi .... ( kui peaks abi täpsustusel olema)
ja mul ka algul ei töödanud see....
vahetasin armatuuris läbipõlenud pirni välja ja hakkas vilkuma :lol: :) :)
Kusjuures, sai proovitud seda pedaalitrikki 2.0 100kw 97 a ja ei toiminud nagu vist tuleb armatuuri kallale minna pirni vahetama ka:D
