Kompuutri kaablid
reims86
Kompuutri kaablid
Postitus Postitas reims86 »
Nii teema siis selles, et paigaldan uut komput autole.
Vana oli kollase pistikuga (väikese ekraaniga kompu) uus on halli pistikuga (suure ekraaniga kompu)
Ja nüüd sain need kaablid kõik ühendatud mis ühtisid ning tekkis küsimus, et kuhu ülejäänud ühendada?
Need paksus kirjas ongi need millest tahaks veel informatsiooni saada.
Pin1(Y2) - Brown - To Chassis (0V)
Pin2(Y3) - Blue/White stripe - Outside temp sensor
Pin3(Y4)- Blue - Outside temp sensor
Pin4(Y5) - Black - To F15 (15A)
Pin5(Y1) - Red - To F12 (20A)
Pin6 - Green - RPM signal
Pin7(Y7) - Grey/Yellow stripe - Instrument Illumination (dimmer controled)
Pin8(Y8) - Red/Grey(white) Stripe - Radio (aerial power feed i.e. Radio on indication)
Pin9(Y9) - Brown/White Stripe - Radio Serial Interface
Pin10(Y10) - Brown/White Stripe - Radio Serial Interface
Pin11(Y11) - Brown/White Stripe - Radio Serial Interface
Pin12(B8) - Blue/Black Stripe - Fuel level sender
Pin13(B11) - Brown/Grey Stripe - Oil level sensor
Pin14(Y14) - Brown/White Stripe - To pin 8 of diag connector (to support programming)
Pin15(Y15) - Black/Yellow stripe - To check control
Pin16(Y16) - Black - To F2 (15A)
Pin17(Y17) - White/Green stripe - To check control
Pin18(Y18) - Black/Yellow stripe - To check control
Pin19(Y19) - Yellow/Red stripe - To brake pad wear sensors
Pin20 - NC
Pin21(Y23) - Grey - To Auto transmission
Pin22(B10) - Brown/Yellow Stripe - Washer Level sensor
Pin23(B5) - Brown/White Stripe - Computer stalk buttons
Pin24(B6) - Brown/Red Stripe - Computer stalk buttons
Pin25 - NC Mis see NC veel tähendab?
Pin26(Y12) - Blue/red stripe - Speed signal (from ABS controller)
Pin27(B9) - Black/Brown Stripe - ECU signal
Pin28(B3) - Brown/Blue stripe - Coolant level sensor
Pin29 - Black/Violet Stripe - To Hid lighting
Pin30 - To Diesel fuel pump (X20DTH only)
(ok see on diislile)
Tegu siis 97a 100kw manuaalkastiga
Aitähh 8)
reims86
Re: Kompuutri kaablid
Kas keegi siis tõesti ei mõista ütelda, et kuhu allnimetatud kaablid ühendada :shock:
vivaldi
Postitus Postitas vivaldi »
reims86 kirjutas:Kas keegi siis tõesti ei mõista ütelda, et kuhu allnimetatud kaablid ühendada :shock:
Kuna sul xenonit ei ole siis pole ka see vajalik :D
jullo
Postitus Postitas jullo »
Pin 6: RPM Signal -- Spidoplokki pin22 külge tuleb juhe ühendada. Mootori pöörete signaal.
Pin12: Spidoplokki pin23 külge. Kütuse taseme anduri signaal
Pin13: Õlitaseme andur. Kui su autol seda pole siis proovi massi ühendada. Minu autol siis enam veateadet ei ilmunud
Pin22: Aknapesu vedeliku taseme andur. Kah massi kui ei ole sellist asja autol
Pin27: ECU Signal. ECUsse pin21 külge. Signaal kütuse pihustamise aja kohta
Pin 28: Jahutusvedeliku taseme andur. Kui seda ka pole siis massi.
Pin29: Xenon tuledele. Tulede kõrgusregulaatori kontrollerile pin20 külge.
Pin20, 25 NC - Pole kasutusel
reims86
Aaga milline see pin22 ja pin23 on sest seal on ainult nr 1 kuid kuidapidi neid lugeda?
Kindel,et ainult nr.1 on kirjas,aju pistikul on nt.iga rea alguse ja lõpu nr. et ei tekiks teistmoodi mõtlemist.Ehk siis kui nr.on õigetpidi ees,siis vasakult paremale ja ülevalt alla.
Panen ühe näitliku pildi.
jullo
Kui ma ei eksi, siis olid rea alguse ja lõpu pin`id märgitud hoopis spidoploki poolsele pistikule, sellele kilest "trükkplaadile"
EDIT: Suures targutamise tuhinas jätsin kahe silma vahele, et sul 97a massin :roll: :roll: . Sellel vähe teistmoodi läheb ühendus spidoplioki ja ecu külge :o :oops: :
12 Fuel sender... läheb spidoploki pin 23 asemel pin 19 alla
27 ECU signal -- Ecule pin 14 alla mitte 21
Ülejäänu toimivad endiselt
reims86
Kuhu see võiks minna. (Pärit kollaselt pistikult hallile pistikule ei oska küll kuhugi ühendada) Pin 6 - Grey/Green stripe - To F26 (10A)
Pin27: ECU Signal. ECUsse pin14 külge. Signaal kütuse pihustamise aja kohta Kuid kuhu ta välja peaks jõudma st üks ots on ECUs kuid kuhu teine pool kaablist jõuab?
enamus kaableid on paigaltatud kuid kompu näitab ikka ainult läbisõidetud distantsi ja temperatuuri :cry:
jullo
reims86 kirjutas:Pin27: ECU Signal. ECUsse pin14 külge. Signaal kütuse pihustamise aja kohta Kuid kuhu ta välja peaks jõudma st üks ots on ECUs kuid kuhu teine pool kaablist jõuab? :cry:
MInu autol ei jõudnudki ta eriti kaugele. Aku kõrval on kaks silindrilist pistikut, mis ecu`st tulevad, kõrvuti. Sinna ainult jõudiski. Juhtme vedasin salongist kapoti alla ecu karpi ja toppisin sinna samma juhtmele külge. Skeemi järgi on must juhe pruuni triibuga.
reims86 kirjutas:Kuhu see võiks minna. (Pärit kollaselt pistikult hallile pistikule ei oska küll kuhugi ühendada) Pin 6 - Grey/Green stripe - To F26 (10A)
:cry:
Jutu järgi siis kaitsmeplokist 26 kaitsme alt tuleb see. Halli pistikuga sellist juhet pole nagu tarvis, seega jäta esialgu see ühendamata :wink:
Kütusekulu ja jms jaoks ongi kompul vaja teada kui palju kütust hetkel pihustatakse, Seda inffi annab talle seesamune pin27(ecu signal). Kui see ühendamatta, siis ta ei saagi seda näidata :roll:
Nokia
Postitus Postitas Nokia »
mis vanade asjadega tegid? Alles? Müügiks + paigaldus on mõeldav? :)
reims86
Vanad asjad täitsa alles st kompu ja üks pistik (kollane) Pixlid pole 100% alles :(
Mida täpsemalt paigalduse all mõtled?
Nokia
reims86 kirjutas:Vanad asjad täitsa alles st kompu ja üks pistik (kollane) Pixlid pole 100% alles :(
Mul endal on kang olemas, aga puudub siis ühendus seal kapoti all ja kompuutri vahel, et näha siis küttekulu, kui metsas see pixli teema sul on? mul üks kompu veel kuskil vedeleb, mby saab kombineerida isegi.
reims86
Nokia kirjutas:
Mul vana oli väikse ekraaniga ja seega ilma kangita näitas ainult kella, temperatuuri ja originaal makipuhul raadiot.
Nokia
reims86 kirjutas:
Nokia kirjutas:
siis küll, kus maal sa hetkel omadega oled? Näitab sul pilti ka juba?
reims86
No põhimõtteliselt asi kõik toimiks kui leiaks ECUlt õige otsa ülesse, et saaks kütusekohta andmeid.
