Tere!
Keegi teab mõnd linki kus seletatud hoiatustulede tähendused armatuuris?Autoks Omega 2001 2,2.Põleb sümbol kus peal auto ja mutrivõti keskel? Auto samas külmalt käib vappuvalt.Kas need omavahel seotud?
Tuled armatuuris.
Re: Tuled armatuuris.
Engine electronics, transmission
electronics, immobil izer
Control indicator lights up for a few
seconds when ignition is switched on.
If it lights up when the engine is running:
Fault in the engine electronics or
transm ission elec tronics sy stem. The
electronic system switches to limp-home
mode. Fuel consumption may increase and
the d riveability of the vehicle may be
impaired; see pag e 150. If there is a fault in
the transmission elec tronics system, switch
to manual gears; see page 138. We
recommend that you consult your Vauxhall
Authorised Repairer.
Selline tekst siis Facelifti kasutusjuhendis.
consa
Väga tore siis.Huvitav on see et ta ei põle igakord.Peab siis diagnossi vurama.
