Omega A 1986-1993
18NV 1.8i 8V I4 83 PS (82 hp/61 kW) 135 N·m (100 lb·ft) MY 1986-1987
18SV 1.8 I4 90 PS (89 hp/66 kW) 148 N·m (109 lb·ft) MY 1986-1987
E18NVR 1.8S I4 88 PS (87 hp/65 kW) 143 N·m (105 lb·ft) MY 1987-1990
18SEH 1.8i I4 116 PS (114 hp/85 kW) 160 N·m (118 lb·ft) MY 1986-1992
C20NEJ 2.0i I4 99 PS (98 hp/73 kW) 170 N·m (125 lb·ft) MY 1990-1993
C20NEF 2.0i I4 101 PS (100 hp/74 kW) 158 N·m (117 lb·ft)
C20NE 2.0i I4 116 PS (114 hp/85 kW) 170 N·m (125 lb·ft) MY 1986-1993
20SE 2.0i I4 122 PS (120 hp/90 kW) 175 N·m (129 lb·ft) MY 1986-1987
C24NE 2.4i I4 125 PS (123 hp/92 kW) 195 N·m (144 lb·ft) MY 1988-1993
C26NE 2.6i I6 110 PS (108 hp/81 kW) 220 N·m (162 lb·ft) MY 1990-1993
C30LE 3.0i I6 156 PS (154 hp/115 kW) 230 N·m (170 lb·ft) MY 1986-1988
30NE 3.0i I6 177 PS (175 hp/130 kW) 240 N·m (177 lb·ft) MY 1986-1990
C30NE 3.0Si I6 177 PS (175 hp/130 kW) 240 N·m (177 lb·ft) MY 1990-1993
C30SEJ 3.0i 24V I6 200 PS (197 hp/147 kW) 265 N·m (195 lb·ft) MY 1990-1993
C30SE 3000 24V I6 240 PS (237 hp/177 kW) 270 N·m (199 lb·ft) MY 1989-1993 (Omega 3000)
C30XEI 3.0 Evo 500 I6 230 PS (227 hp/169 kW) 280 N·m (207 lb·ft) MY 1991-1993 (Irmscher for Omega Evo 500)
C36NEI 3.6i 24V I6 210 PS (207 hp/154 kW) (Irmscher)
C36NE 3.6i 24V I6 199 PS (196 hp/146 kW) (Irmscher)
C40SE 4.0i 24V I6 272 PS (268 hp/200 kW) 395 N·m (291 lb·ft) MY 1991-1992 (Irmscher)
C36GET 3.6i 24V I6 377 PS (372 hp/277 kW) 557 N·m (411 lb·ft) MY 1991-1992 (Omega Lotus)
23YD 2.3 D I4 73 PS (72 hp/54 kW) 138 N·m (102 lb·ft) MY 1986-1993
23YDT 2.3 TD I4 90 PS (89 hp/66 kW) 190 N·m (140 lb·ft) MY 1986-1988
23DTR 2.3 TD I4 101 PS (100 hp/74 kW) 218 N·m (161 lb·ft) MY 1988-1993
Opel Omega B 1994-03
X20XEV 2.0i 16V I4 136 PS (134 hp/100 kW) 185 N·m (136 lb·ft) MY 1994-1999
Y22XEV 2.2i 16V I4 145 PS (143 hp/107 kW) Until MY 2000
Z22XEV 2.2i 16V I4 145 PS (143 hp/107 kW) MY 2001-2003
X25XE 2.5 24V V6 170 PS (168 hp/125 kW) 227 N·m (167 lb·ft) MY 1994-2000
Y26SE 2.6 24V V6 180 PS (178 hp/132 kW) 240 N·m (177 lb·ft) MY 2001-2003
X30XE 3.0 24V V6 211 PS (208 hp/155 kW) 270 N·m (199 lb·ft) MY 1994-2000
Y32SE 3.2 24V V6 218 PS (215 hp/160 kW) 290 N·m (214 lb·ft) MY 2001-2003
X20DTH 2.0 DTI 16V I4 101 PS (100 hp/74 kW) 205 N·m (151 lb·ft) MY 1998-2000
Y22DTH 2.2 DTI 16V I4 120 PS (118 hp/88 kW) 280 N·m (207 lb·ft) MY 2000-2003
X25DT 2.5 TD I6 131 PS (129 hp/96 kW) 250 N·m (184 lb·ft) MY 1994-2000
Y25DT 2.5 DTI I6 150 PS (148 hp/110 kW) 300 N·m (221 lb·ft) MY 2001-2003
Kes siis Nm midagi eriti ei jaga, siis võrdluseks, et Lotus Omegal Nm e. pöördemoment on 557Nm 4200 pöördel.
Omega mootorite Data
Re: Omega mootorite Data
Panen ka siia, kes tahab täpsemalt.Kui keegi jooniseid soovib võib küsida.
All engines manufactured by Vauxhall/Opel - as with those of all vehicle manufacturers - have identification codes, which reveal information about a particular engine. For clarity, an example of a Vauxhall/Opel engine identification code is 'C20LET'. See that engine's node for explanation of the engine and how the designation relates to its specification.
The standard form of such an identification number (for petrol engines, as opposed to diesel engines) is as follows:
ABBCCDE
Where:
A = Exhaust emission standard ahered to by the engine in question (in this case, they are European Community directives pertaining to emission limits). One of the following:
'C' = EC 91/441/EEC
'X' = EC 91/441/EEC (stage 2)
Where there is no letter, the engine adheres to EC directive ECE R 83 A.
B = Engine capacity in cubic centimetres (cc). This is a two digit number - e.g. '20' means 2.0 litres, '35' means 3.5 litres.
C = Compression Ratio. One of the following:
'G' = less than or equal to 8.5:1
'L' = 8.5:1 to 9.0:1
'N' = 9.0:1 to 9.5:1
'S' = 9.5:1 to 10.0:1
'X' = 10.0:1 to 11.5:1
'Y' = more than or equal to 11.5:1
D = Mixture system. One of the following:
'E' = Multi-point fuel injection
'Z' = Central injection
'V' = Carburettor
E = Specific vehicle version. This is often not used, and little information exists on the meaning of all the variants of this segment of the code. Some of them are:
'H' = High output/supercharging
'V' = Volume model
'R' = Increased output
'T' = Turbo
As an example, one of Vauxhall/Opel's recent engines, the X25XE (going through the identification in part order):
X - adheres to EC emission directive EC 91/441/EEC (stage 2)
25 - has a 2.5 litre capacity
X - has a compression ratio of 10.0:1 to 11.5:1
E - has multi-point fuel injection.
In addition to this, if one were to search out the engine number of the particular engine (as found stamped on the engine block, usually in front of the clutch housing), one would likely find an extended version of the code as described above, with further details in the form:
ABBCCDEFFGGGGG
ABBCCDE are as described above.
FF = Country of manufacture. One of the following:
'01' = Rüesselsheim
'02' = Bochum
'08' = Ellesmere Port
'14' = Kaiserslautern
'19' = Aspern
'20' = Hungary
'25' = Holden
'31' = Brazil
'0S' = Szentgotthard
GGGGG is the engine serial number.
Agila
Z10XE 3 973 43/58 Benziner 1.4 - 2.2 Ecotec
Z12XE 4 1199 55/75 Benziner 1.4 - 2.2 Ecotec
Ascona A / Manta A (Bj. 1970-1975)
12S 4 1187 44/60 Benziner OHV
16N 4 1566 44/60 Benziner CIH
16S 4 1566 55/75 Benziner CIH
19S 4 1875 65/90 Benziner CIH
19E 4 1875 77/105 Benziner CIH
Ascona B / Manta B (Bj. 1976-1981)
12N 4 1187 40/55 Benziner OHV
13N 4 1281 44/60 Benziner OHC
13S 4 1281 55/75 Benziner OHC
18S 4 1771 66/90 Benziner OHC
19N 4 1875 55/75 Benziner CIH
19S 4 1875 66/90 Benziner CIH
20N 4 1956 66/90 Benziner CIH
20S 4 1956 74/100 Benziner CIH
20E 4 1956 81/110 Benziner CIH
I20E 4 1956 92/125 Benziner CIH
24E 4 2390 106/144 Benziner A400
Ascona C (Bj. 1982-1988)
16N 4 1587 55/75 Benziner OHC
16S 4 1587 Benziner OHC
16SH 4 1587 66/90 Benziner OHC
16SV 4 1587 60/82 Benziner OHC
E16NZ 4 1587 55/75 Benziner OHC
C16LZ 4 1587 55/75 Benziner OHC
C16NZ 4 1587 55/75 Benziner OHC
18E 4 1771 85/115 Benziner OHC
18SE 4 1771 82/112 Benziner OHC
C18NE 4 1771 74/100 Benziner OHC
E18NV 4 1771 62/84 Benziner OHC
S18NV 4 1771 Benziner OHC
20NE 4 1984 85/115 Benziner OHC
C20NE 4 1984 85/115 Benziner OHC
C20NEF 4 1984 74/100 Benziner OHC
20SEH 4 1984 95/130 Benziner OHC
Astra Classic (Bj. 1999- )
X14NZ 4 1389 Benziner OHC
X16SZR 4 1598 55/75 Benziner OHC
X16XEL 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec
Astra F (Bj. 1992-1998)
14NV 4 1389 55/75 Benziner OHC
C14NZ 4 1389 44/60 Benziner OHC
14SE 4 1389 60/82 Benziner OHC
C14SE 4 1389 60/82 Benziner OHC
X14XE 4 1389 66/90 Benziner 1.4 - 2.2 Ecotec
16LZ2 4 1598 55/75 Benziner OHC
16NZ2 4 1598 Benziner OHC
16NZR 4 1598 Benziner OHC
C16NZ 4 1598 55/75 Benziner OHC
X16SZ 4 1598 52/71 Benziner OHC
C16SE 4 1598 74/100 Benziner OHC
X16NE 4 1598 Benziner OHC
18SE 4 1796 Benziner OHC
C18NZ 4 1796 66/90 Benziner OHC
C18SEL 4 1796 Benziner OHC
C18XE 4 1796 92/125 Benziner 1.4 - 2.2 Ecotec
X18XE 4 1796 85/115 Benziner 1.4 - 2.2 Ecotec
C18XEL 4 1796 85/115 Benziner 1.4 - 2.2 Ecotec
C20NE 4 1998 85/115 Benziner OHC
X20XEV 4 1998 100/136 Benziner 1.4 - 2.2 Ecotec
C20XE 4 1998 110/150 Benziner DOHC
Astra G (Bj. 1998- )
X12XE 4 1199 Benziner 1.4 - 2.2 Ecotec
X14XE 4 1389 Benziner 1.4 - 2.2 Ecotec
Z14XE 4 1389 Benziner 1.4 - 2.2 Ecotec
Z16SE 4 1598 62/85 Benziner OHC
C16SEL 4 1598 Benziner 1.4 - 2.2 Ecotec
Z16XE 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec
X18XE1 4 1796 85/115 Benziner 1.4 - 2.2 Ecotec
Z18XE 4 1796 92/125 Benziner 1.4 - 2.2 Ecotec
Z18XEL 4 1796 Benziner 1.4 - 2.2 Ecotec
X20XER 4 1998 Benziner 1.4 - 2.2 Ecotec
Z20LET 4 1998 141/192 Benziner Turbo 1.4 - 2.2 Ecotec
Z22SE 4 2198 108/147 Benziner 1.4 - 2.2 Ecotec
Calibra (Bj. 1989-1997)
C20XE 4 1984 110/150 Benziner DOHC
X20XEV 4 1984 100/136 Benziner 1.4 - 2.2 Ecotec
C20LET 4 1984 150/204 Benziner Turbo DOHC
C25XE 6 2498 125/170 Benziner V6
X25XE 6 2498 Benziner V6
Commodore C (Bj. 1978-1986)
25S 6 2461 85/115 Benziner CIH
25E 6 2461 96/130 Benziner CIH
Corsa A (Bj. 1983-1992)
10S 4 986 33/45 Benziner OHV
12N 4 1187 33/45 Benziner OHV
12NC 4 1187 33/45 Benziner OHV
E12GV 4 1187 33/45 Benziner OHV
12S 4 1171 40/55 Benziner OHC
12ST 4 1196 40/55 Benziner OHC
12NV 4 1196 38/52 Benziner OHC
C12NZ 4 1196 33/45 Benziner OHC
13S 4 1281 51/70 Benziner OHC
13SB 4 1281 51/70 Benziner OHC
13NB 4 1281 44/60 Benziner OHC
C13N 4 1281 44/60 Benziner OHC
14NV 4 1389 44/60 Benziner OHC
E16SE 4 1587 74/100 Benziner OHC
C16SE 4 1587 72/98 Benziner OHC
Corsa B (Bj. 1993-2001)
X10XE 3 973 40/54 Benziner 1.4 - 2.2 Ecotec
12NZ 4 1195 33/45 Benziner OHC
C12NZ 4 1195 33/45 Benziner OHC
X12SZ 4 1195 33/45 Benziner OHC
X12XE 4 1199 48/65 Benziner 1.4 - 2.2 Ecotec
13NE 4 1281 Benziner OHC
X14SZ 4 1389 44/60 Benziner OHC
C14SEL 4 1389 Benziner 1.4 - 2.2 Ecotec
C16XE 4 1598 80/109 Benziner 1.4 - 2.2 Ecotec
X16XE 4 1598 78/106 Benziner 1.4 - 2.2 Ecotec
Corsa C (Bj. 2001- )
Z14XE 4 1389 66/90 Benziner 1.4 - 2.2 Ecotec
Z16SE 4 1598 Benziner OHC
Frontera A (Bj. 1992-1998)
X20SE 4 1998 85/115 Benziner OHC
X22XE 4 2198 100/136 Benziner 1.4 - 2.2 Ecotec
C24NE 4 2410 92/125 Benziner CIH
Frontera B (Bj. 1999- )
X22SE 4 2198 Benziner 1.4 - 2.2 Ecotec
Y22SE 4 2198 100/136 Benziner 1.4 - 2.2 Ecotec
GT (Bj. 1968-1973)
11S 4 1078 44/60 Benziner OHV
Kadett B/C (Bj. 1965-1979)
10N 4 986 29/40 Benziner OHV
10S 4 986 35/48 Benziner OHV
11N/L/SR 4 1078 33/45 Benziner OHV
11S 4 1078 41/55 Benziner OHV
12N 4 1187 38/52 Benziner OHV
20EH 4 1956 85/115 Benziner CIH
Kadett D (Bj. 1980-1984)
10S 4 986 Benziner OHV
12N 4 1187 39/53 Benziner OHV
12ST 4 1171 40/55 Benziner OHC
16S 4 1566 Benziner OHC
Kadett E (Bj. 1985-1993)
12SOHV 4 1187 44/60 Benziner OHV
12SCOHV 4 1187 40/55 Benziner OHV
12SOHC 4 1171 40/55 Benziner OHC
12STOHC 4 1171 40/55 Benziner OHC
C18NT 4 1771 66/90 Benziner OHC
C18NZ 4 1771 66/90 Benziner OHC
20SER 4 1984 91/124 Benziner OHC
20XEJ 4 1984 110/150 Benziner DOHC
Monza / Senator A (Bj. 1978-1987)
20E 4 1956 85/115 Benziner CIH
22E 4 2182 85/115 Benziner CIH
H25E
6 2461 100/136 Benziner CIH
25E 6 2461 103/140 Benziner CIH
28H 6 2753 103/140 Benziner CIH
30H 6 2935 110/150 Benziner CIH
30E 6 2935 132/180 Benziner CIH
C30NE 6 2935 115/156 Benziner CIH
Omega A (Bj. 1987-1993)
18NV 4 1771 60/82 Benziner OHC
18SEH 4 1771 85/115 Benziner OHC
18SV 4 1771 66/90 Benziner OHC
E18NVR 4 1771 65/88 Benziner OHC
20SE 4 1984 90/122 Benziner OHC
C20NEJ 4 1984 73/99 Benziner OHC
C24NE 4 2393 92/125 Benziner CIH
C26NE 6 2594 110/150 Benziner CIH
30NE 6 2935 130/177 Benziner CIH
C30LE 6 2935 115/156 Benziner CIH
C30NE 6 2935 130/177 Benziner CIH
C30SE 6 2935 150/204 Benziner DOHC
C30SEJ 6 2935 147/200 Benziner DOHC
C30XEI 6 2935 169/230 Benziner DOHC
C36GET 6 3615 277/377 Benziner Turbo DOHC
Omega B (Bj. 1994- )
Y22XE 4 2198 Benziner 1.4 - 2.2 Ecotec
Z22XE 4 2198 106/144 Benziner 1.4 - 2.2 Ecotec
X25XE 6 2498 125/170 Benziner V6
Y26SE 6 2597 132/180 Benziner V6
X30XE 6 2962 155/210 Benziner V6
Y32SE 6 3175 160/218 Benziner V6
Rekord D / E (Bj. 1972-1986)
17N 4 1679 49/66 Benziner CIH
17S 4 1679 61/83 Benziner CIH
18N 4 1771 55/75 Benziner OHC
C18NV 4 1771 74/100 Benziner OHC
19SH 4 1875 71/97 Benziner CIH
Senator B (Bj. 1988-1994)
25NE 6 2461 103/140 Benziner CIH
Sintra (Bj. 1997-1999)
X22XE 4 2198 104/141 Benziner 1.4 - 2.2 Ecotec
X30XE 6 2962 148/201 Benziner V6
Speedster (Bj. 2001- )
Tigra (Bj. 1995- )
Vectra A (Bj. 1989-1995)
14NV 4 1389 Benziner OHC
X16SZ 4 1587 52/71 Benziner OHC
C16LZ2 4 1587 Benziner OHC
C16NZ2 4 1587 55/75 Benziner OHC
Vectra B (Bj. 1996- )
Y16XE 4 1598 Benziner 1.4 - 2.2 Ecotec
X18XE 4 1799 85/115 Benziner 1.4 - 2.2 Ecotec
20NEJ 4 1998 80/109 Benziner OHC
C20SEL 4 1998 Benziner 1.4 - 2.2 Ecotec
C22SEL 4 2198 Benziner 1.4 - 2.2 Ecotec
6 2498 143/195 Benziner V6 (Irmscher)
Y26SE 6 2597 125/170 Benziner V6
Zafira (Bj. 1998- )
Z12XE 4 1199 Benziner 1.4 - 2.2 Ecotec
X16SZR 4 1598 Benziner OHC
Z16SE 4 1598 Benziner 1.4 - 2.2 Ecotec
X20XEV 4 1998 Benziner 1.4 - 2.2 Ecotec
ABBCCDE
Where:
'C' = EC 91/441/EEC
'V' = Carburettor
'V' = Volume model
'T' = Turbo
ABBCCDEFFGGGGG
'01' = Rüesselsheim
'02' = Bochum
'19' = Aspern
'20' = Hungary
'25' = Holden
'31' = Brazil
Agila
GT (Bj. 1968-1973)
H25E
Tigra (Bj. 1995- )
Zafira (Bj. 1998- )
